7. Add fields
This procedure allows the creation, modification and deletion of fields in a specific element of the system or in all elements of the same type (cat_feature).
This functionality is useful when it is necessary to store information that is not contemplated in the standard Giswater data model.
It is important to highlight that the additional fields system does not directly add columns to the parent tables (node, arc, connec). For this reason, these fields cannot be queried directly in those tables, but they will be available:
  • In the QGIS forms.
  • In the child views.
General description
To carry out this process, it is necessary to have administrator permissions, since the affected views are automatically modified when an additional field is created, updated, or deleted.
The process consists of two distinct steps:
  1. Creation of the field in the database, described in this protocol.
  2. Configuration of the field display in the dialog, detailed in the protocol config_form_fields
Technical considerations
The information associated with additional fields is stored in the following tables:
sys_addfields
config_form_fields
Since the view of the element to which an additional field is added is automatically recreated each time a field is created, updated, or deleted, there is a specific function designed to perform all necessary operations related to the management of additional fields in an integrated manner.
Creation of an additional field
The function call is:
SELECT SCHEMA_NAME.gw_fct_admin_manage_addfields(
  $${"client":{"lang":"ES"},
     "feature":{"catFeature":"PUMP"},
     "data":{
        "action":"CREATE",
        "multi_create":"true",
        "parameters":{
           "columnname":"addfield_all",
           "datatype":"string",
           "widgettype":"text",
           "label":"addfield_all",
           "ismandatory":"False",
           "fieldLength":"50",
           "numDecimals": null,
           "active":"True",
           "iseditable":"True"
Function parameters
SCHEMA_NAME: is the name of the schema.
“catFeature”: is the feature to which we want to add a new field.
“action”: the action we intend to perform, which in this case will be CREATE.
“multi_create”: SUPER IMPORTANT, allows the creation of the additional field FOR ALL FEATURES of the same type (nodes, arcs, connec, or gully depending on the one chosen)
“columnname”: the name of the additional field. Special characters are strictly prohibited.
“datatype”: the data type, consult the available ones in this query:
SELECT id
 FROM SCHEMA_NAME.config_typevalue
 WHERE typevalue = 'datatype_typevalue'
“widgettype”: the type of widget to be used, consult the available ones in this query:
SELECT id
 WHERE typevalue = 'widgettype_typevalue'
“label”: “addfield_all”, the label to display to the user in the dialog.
“ismandatory”: whether the field is mandatory for the user
“fieldLength”: length of the field.
“numDecimals”: number of decimals.
“active”: whether the field is active or we want to leave it for another time.
“iseditable”: whether the field is editable by the user.
Warning
Be careful with the syntax of JSON requests. It is very easy to make mistakes. We recommend being very careful at this point.
Deletion of an additional field
If we wanted to delete an additional field, we would proceed as follows:
SELECT SCHEMA.gw_fct_admin_manage_addfields($${
"data":{"action":"DELETE", "multi_create":"true", "parameters":{"columnname":"pump_test"}}}$$)
