Breakdown assignation tool
Tool that allows assigning leaks over the network.
../../../../_images/breakdown-assignation.png
Window of the breakdown assignation tool.
The window contains the following buttons:
Leaks
  • Safety distance (m): search radius around each leak.
  • Years to calculate: temporal limit for the analysis.
  • Use all leaks: ignores the year filter and uses all registered leaks.
Pipes
  • Maximum distance (m): maximum distance between leak and pipe.
  • Cluster length (m): minimum length of the grouped section.
  • Filter by material: activates the filter by material of the pipe.
  • Filter by diameter: activates the filter by diameter.
  • Diameter range: allowed diameter range.
  • Filter by construction date: activates the filter by construction year.
  • Construction date range (years): defines the temporal range for the pipes.
